Originally Posted by chuck_s_jr
ford build their own like GM did back in the 1980s I hope they did better, I seen no real problem with the 6.4 it was do to the 6.0 ford terminated with Navistar.
The 6.0L did not meet the next tier of emissions requirements, hence the 6.4L. I bet when everything is said and done, the 6.4L, in it's 3 year life span, will end up costing Ford nearly the same as the 6.0L in it's 7 years of existance. Warranty repair costs are very very very high. Whenever there is an engine failure, Ford has the dealer do a cost cap. If it's over a certain mark, they usually send out an inspector and approve a engine. If the cost cap is below, the dealer repairs what ever the concern is (short block, cylinder head, ect.). Typical cost caps for me average $5,000 to $8,000 for a 6.0L. The last one I did for a 6.4L was nearly $18,000 after a horizontal EGR cooler went out. I believe the 6.7L will be a solid engine. Ford produces a lot of diesel engines in Europe and those are bullet proof. The 2011 is the only Super Duty I'd consider buying since the 7.3L
