Glow Plug
Originally Posted by bismic
In 2004 the design of the piston changed. This required the installation of a shorter glow plug by 1.2 mm. If the longer glow plugs are installed into an engine with updated pistons, glow plug to piston contact will result, ending in potential catostrophic engine failure.
Look it up and post the part number if a glow plug was replaced (and in which cylinder).
WHERE YOU GETTING ANY CODES IF THE GLOW PLUG WAS DAMAGED IT WOULD THROW A CODE AND SHOW WHICH GLOW PLUG WAS BAD MINE DOES
THIS WHOLE POST SOUNDS FISHY WITH FORD I WOULD HAVE A ATTORNEY WRITE A LETTER TO FORD AND ADDRESS IT TO CEO OF FORD KEEP ALL PAPER WORK AND DOCUMENT EVERYTHING HANG IN THERE AND BE PERSISTANT I THINK THEY WILL EVENTUALLY HAVE TO FIX IT
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
