Diesel Forum - TheDieselStop.com - View Single Post - HPOP question
Thread: HPOP question
Old 11-06-2009, 12:43 PM   #6 (permalink)
sdan27
I believe he is saying that in the early model powerstrokes, the anti-drainback valve was in the hpop itself, whereas in the later model, as a '99 would be, the drainback valve was in the front cover. I would also recommend installing an Adrenaline HPOP as was previously stated. Check out dieselsite.com, they sell the Adrenaline pump and they can answer any questions you have regarding hpops.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline   Reply With Quote
