Diesel Forum - TheDieselStop.com - View Single Post - PowerSteering Fluid, Type ?
Old 11-06-2009, 12:50 PM   #11 (permalink)
boomboom
boomboom's Avatar
If you put DEX3/MERCON in you are good to go, If type F was used you might want to change it. You do not need MERCON 5
boomboom is offline   Reply With Quote
