Originally Posted by schoolde
I agree 100% with BTBBT, I haven't had my CPS done either, three notices so far. Seems like when they start "fixing" what isn't broke, a whole bunch of other things pop up. This speed control thing, is it only a problem if you use the speed control, or can it be a problem at anytime?
I believe it has nothing to do with using it or not. Its a preasure switch on brake master cylinder that can leak from brake fluid preasure and then short out harness and start a fire. I guess if you dont use your brakes you won't have a problem
