Originally Posted by boomboom
If you put DEX3/MERCON in you are good to go, If type F was used you might want to change it. You do not need MERCON 5
OK .
The Manual says Mercon ATF , for adding or re fill .
So far there are way too many kinds of red stuff for me to mentally grasp. I'm not the britest bulb on the tree.
Which flavor of Mercon is assumed to being the correct flavor in the manual stating " Ues only Mercon ATF" for power steering
Mercon SP
Mercon 5
Mercon
Dextron 3
Does Mercon indicate synthetic , or the designation abc,123 ect ?
