Diesel Forum - TheDieselStop.com - View Single Post - anyone ever put 3" bodylift on 2000 f350 diesel?
Old 11-06-2009, 02:34 PM   #10 (permalink)
69mach1377
69mach1377's Avatar
Originally Posted by Snyder3 View Post
I had a 3" body lift on my 02 crew cab. I never had a single problem. The only way a body lift will change the "ride" is if you install polyurethane cab bushings when you install the body lift, they are harder than the oe rubber cab bushings. Some people say body lifts are cheap and dumb, thats their opinion. It's your truck, use the kit for a V10, it will be safe, just use your head when putting really heavy things in the bed, a quad, fine, a full bed of gravel or dirt, probably not fine. I agree with you that those last 3" can cost a bundle with x-over steering, driveshafts, etc. Body lift is way cheaper, just make sure you get lift lips to hide the gap. BTW, I put the body lift on my old 02 because I tow a large toyhauler, wanted 40"s, and did not want a super long drop hitch. With a body lift your hitch will not be raised, I had a 6" drop, perfect. When you raise your rear bumper, only go up 1.5", it will fit the body of the truck o.k., and your reciever won't look like it's in no mans land. Hope this helps!
Snyder, where were you when asked this question a while back? Everyone said no way. I was thinking of just 1-2 inches. Does anyone make a body lift kit that small? Will it mess up a 5th wheel hitch setup?
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline   Reply With Quote
