Diesel Forum - TheDieselStop.com - View Single Post - upgrade intercooler ? ? ?
Old 11-06-2009, 03:32 PM   #4 (permalink)
ronchyhiker
6.0 Intercooler In 7.3
This a follow-up on your reply, on what I posted,in regard to 6.0 intercooler in a 7.3. Can you get me the measurement of the 6.0 intercooler you used? I bought a used one and the core is narrower, by4in.than the 7.3 but it is higher and thicker. Is there more than one type? I am trying to figure out if it is worth the effort of exchanging them.
Thanks for your reply
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline   Reply With Quote
