Normal average operating temperatures on a gasoline engine(may or may not be comparable to a diesel) usually run @ or around 230*F. Anyone with a scan tool can check this. Only advantage I see of having a 203* is idle temps can be higher, and most larger trucks idle more so I can see the benefit of the 203*. I have one, and I do get more warm air when idling than I did before, but that is about the only effect of having it.
DD 2010 Ford Fusion Sport
relegated to garage duty
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
