Diesel Forum - TheDieselStop.com - View Single Post - installing group 31 batteries
Old 11-06-2009, 07:43 PM   #2 (permalink)
sdan27
With the factory set-up, they are a little tall and wanted to catch on the hood a little. Might not have been a big deal since the hood has that cloth-like insulation on the inside but I didn't want it to become a problem. There is adjustment in the battery holders that you can drop them down further but I think I modified mine so they'd drop a little futher yet. Then I stuck a piece of plywood behind them and hooked them in place with a bungie strap. Like it a whole lot better than the factory set-up and probably one of the best mods I've done. I think I did it four, maybe five years ago. Guess I should add that to my signature.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline   Reply With Quote
