Diesel Forum - TheDieselStop.com - View Single Post - looking at an 04 6.0
Old 11-06-2009, 10:08 PM   #33 (permalink)
bigwhite1
bigwhite1's Avatar
the guys are right ,it's not if but when, 60-70k is about when they start. they have a design flaw in the motor- egr cooler-oil cooler and head gaskets. head gaskets can be minimized by the egr delete and coolant filter. should be fine after that. you can check the engine by filling up the degaus bottle and run the engine around 3000 rpm on the highway. then stop and have a look at the degaus cap, if there's white residue or anti freeze coming out ,then the problems have started.
unfortunate owner of a 2006 6l diesel,lb,cc and formally a 2004 6l. both puke and both not fixed by ford under warranty
2004 cardinal 33ts
bigwhite1 is offline   Reply With Quote
