Originally Posted by bigwhite1
your math should be 8qts out 27.5 not 8/15.5. if you take 15.5/27= 57% water and 43% antifreeze.
Removed my original math and redid it because you are correctd and I must have been brain dead .......
He left 15.5 quarts of water in and added 8 quarts of pure antifreeze. That now makes 8 quarts out of (15.5+8) or 8 out of 23.5 - that is 35%. Topping off w/ a 50/50 will never get you to a 50% concentration. Topping off w/ 100% will get you to the 43% you mention.
Mark
