Diesel Forum - TheDieselStop.com - View Single Post - 08 F450 Transfer Case Broke????? Help!!
Old 11-07-2009, 12:17 AM   #7 (permalink)
JDawg965
JDawg965's Avatar
There was a slight vibration right when i pulled over... I pulled over because of the vibration, Then i just found out more information... When the tow truck came to pick up the truck he didn't want to use a flat bed because he thought it would not fit.. So he came back and picked it up from the front Drove it two miles and said something doesn't seem right so flipped it around and grabbed it from the rear With a sling not even with a wheel lift!!! in the manual it says do not use a sling??? why would he do that!! i think they will be covering the rest of the damage because the front drive shaft snapped off cracked the transfer case completely apart broke brake lines throttle cable ate up a wire harness i will post pictures asap but it is really bad my transmission guy said he has never seen anything like this..
JDawg965 is offline   Reply With Quote
