wont start help
i just bought a 1991 f350 dually. when i first bought it from the guy it started fine but then it didnt want to start. so i checked batters they were a like 550 cca . i think they were to small so bought 2 1040 cca its turns over fine but doesnt start.check glowplugs 1 was bad replace it. i put electric fuel pump in thinking maybe does have pressure so know i got pressure all the time. still wont start.got newfuel filter air filter still wont start. it wont start in 60 degrees weather . it starts after the 3rd or four time cranking it for 20 to 25 seconds. if it does start after that than i put a spray of starting fluid and starts right up. my questions is could it be the relay and where is it located how do u test if bad or good thxs dually6690
