Diesel Forum - TheDieselStop.com - View Single Post - Leaking oil from plug on Passenger side block.
Old 11-07-2009, 02:26 AM   #3 (permalink)
Jcart
Jcart's Avatar
If that is the leaking plug, which is not uncommon use a 3/8" drive to get it out and new one in.....some long extensions help, can't remember if you have to pull an up-pipe or the DP to get at it though....
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline   Reply With Quote
