Diesel Forum - TheDieselStop.com - View Single Post - Cooling fan upgrade??
Old 11-07-2009, 03:00 AM   #5 (permalink)
Jcart
Jcart's Avatar
ZombieT....how much do you tow and where? It would seem your ride is set up for towing and if so I would keep the stocker fan on....and just run w/o in the winter...Both my trucks have e-fans my '96 design is removable but just the same a hassle and if you tow a bunch there is nothin' like the B52 prop out front to cool things down. If not that much a E-system will work.
As a suggestion I used to run K&N and they are a good product just make sure you're on the maintanence...used to find small dust film on the intake upstream of filter...switched to donaldson paper no dust film....anyways I think I have some pix of the twin E-fans Taurus set up in my pix in truck folder....just for ideas...
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline   Reply With Quote
