Diesel Forum - TheDieselStop.com - View Single Post - adding CAC to existing dt466 motor
Old 11-07-2009, 08:48 AM   #17 (permalink)
drcampbell
My Photos: (5)
Originally Posted by hemivolvo View Post
i don't really know what the ideal gas law is, don't know physics, not too clear on how that helps me. ...
You can use the Ideal Gas Law, (look it up: Ideal gas law - Wikipedia, the free encyclopedia ) the air temperature, the air pressure and the displacement to calculate the mass of air going into each cylinder. When you know the mass of the air, you can calculate the maximum mass of fuel which can be injected before going over-stoichiometric.
You don't need to be concerned about lean air:fuel ratios; that's the normal operating mode of Diesel engines. They're controlled by fuel, not air, and always run lean. The air:fuel ratio may be more than 100:1 when idling or running lightly.
But the maximum amount of fuel is quite another thing. If you attempt to run on the rich side of stoichiometric, you'll convert fuel into smoke, greasy soot, coke and contaminated oil instead of torque & power.
i think this is a pretty simple problem with a simple answer ...
There is: Measure the engine's exhaust gas temperature. When it hits 1200° Fahrenheit, stop increasing fuel delivery. If it goes over 1200° Fahrenheit, the engine will melt.
Measuring the turbocharger's exhaust gas temperature will yield an indirect, variable and unreliable piece of information which will not enable you to protect the engine.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline   Reply With Quote
