Diesel Forum - TheDieselStop.com - View Single Post - Vibration caused by steering arm?
Old 11-07-2009, 09:44 AM   #1 (permalink)
Tony_ONeil
Tony_ONeil's Avatar
Hi there,
I'm getting a vibration that can be felt on the steering wheel when going down the road.
I think I may have found the cause but I'm not sure.
I've greased and re-greased the ends of the rod that connects the steering arm (pitman arm?) to the tie rod on the passengers side and it doesn't seem to do any good.
The ends are always loose. I can grab the bar and make it twist with my hands and it can turn so far as to clunk against the tie rod.
Can this be causing my vibration when going down the road?
2002 F-350 Crew Cab Lariat 4x4 7.3L Auto SRW
AFE Stage II Intake, AFE 4" Turbo-Back Exhaust, CCV Mod, Zoodad Mod, Pre-pump Mod, Flex-A-Lite Tranny Cooler, Draw-Tite Activator II Trailer Brake Control, IC Foil Wrap Delete, 203° Thermostat, Ford reman. Turbo, Fleetrite HD ELC, Rotella 5w-40 Synthetic, 4300K 35Watt dual beam HIDs, DB High-Torque Starter, Isspro EV gauges (trans,boost,pyro), Dp-Tuner F5
Tony_ONeil is offline   Reply With Quote
