Originally Posted by caryt
Hand Made in USA! One thing when using the 80/100w bulbs is do not use a diode to run high and low beams together..will fail!
Yep, never used the diode on them. Thanks.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, custom bed carpet/bench inserts, Rhino grill guard, Bugshield, mud flaps, CCV Mod, AIS w/foam sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD steering stabilizer, C-Btr Mirrors, Hella FF1000, Sonnax/Tricumulator, Htr Bypass valve, 31 row 6.0 tranny cooler,front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
