Diesel Forum - TheDieselStop.com - View Single Post - Help, I live in the mountains
Old 11-07-2009, 11:42 AM   #8 (permalink)
NH2112
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Originally Posted by Steve250 View Post
Please post a link to this system you speak of.
Well, here's a universal V8 system from NOS, but this is something almost anyone can build on their own for far less money.
Holley Performance Products Sniper Universal Wet Kit*07006NOS
Basically, you need a bottle, hose, nozzle, toggle switch, vacuum or oil pressure switch (so system can only be activated when the engine's running), and 2 lockoffs (1 opened & closed by the vac or O.P. switch, the other opened by the toggle switch.) Get the bottle from Amerigas, Merriam-Graves, or any welding/industrial gas supplier. Hoses and necessary fittings come from any hydraulic shop. You can get a nozzle from a speed shop, the vacuum/oil pressure switch and the lockoffs are available from any forklift dealer, and if there's a Skyjack aerial lift dealer nearby (United Rentals, for example), you can order the following part numbers: (part numbers may have changed, my CD manual is over 4 years old.)
2ea 125793, LPG shutoff (lockoff)
1ea 111623, switch, vacuum safety
These are both threaded for 1/8" NPT.
There's also an adjustable nozzle that I couldn't find the Skyjack part number for (it's been a long time since I worked on one and forgot what it looks like LOL), but this
Valve, Flow Control - Pneumatic Flow Control And Needle Valves - Valves - Pneumatics & Hydraulics : Grainger Industrial Supply
or this
Valve, Needle, 1/8 NPT - Pneumatic Flow Control And Needle Valves - Valves - Pneumatics & Hydraulics : Grainger Industrial Supply
should work just fine. Start with it backed off maybe 1 turn from fully closed, and adjust for desired power. Mount away from the engine, the brass one is rated for 140F max and the plastic is 200F.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
NH2112 is online now   Reply With Quote
