Diesel Forum - TheDieselStop.com - View Single Post - adding CAC to existing dt466 motor
Old 11-07-2009, 12:21 PM   #19 (permalink)
Evel486
Wow. Lot's of information & a little misinformation.
Don't worry about the ideal gas law. This is a low tech very simple diesel engine. Stress DIESEL engine. There is no air/fuel ratio to worry about.
Your pyro pick-up is fine where it is. You need a relative temp so post turbo keep it below 1000 deg. Short spikes to 1100-1200 deg are acceptable but not for prolonged periods.
If you have a rotary pump (injector lines come off in a circle from the top of the pump) you have an Ambac Model 100 pump. You stated in an earlier post a diesel tech showed you the max fuel screw (if not, post it & I'll guide you) Turn this screw out 1/4 turn and road test. If you can't get your temp up under heavy load, turn it some more. If it comes up too quick, turn it back. Repeat until you are happy.
If you have an inline pump (injector lines come off in a straight line) you have a Bosch pump with RSV governor. If so, post this and I'll guide you through setting it up.
Evel486 is offline   Reply With Quote
