Diesel Forum - TheDieselStop.com - View Single Post - High Pressure Oil Reservoir
Old 11-07-2009, 04:13 PM   #3 (permalink)
woodnthings8
woodnthings8's Avatar
From previous post, most do not change the HPOP reservoir oil. I have done it a few times but not every time. Most claim it to be a waste of time. I do believe it helps a little bit because you do leave around 3 quarts in the reservoir and oil galleries when you do a oil change. This oil gets mixed with the new oil and you technically have decreased the new oils properties. Now is it enough to matter? Probably not, I have seen oil analysis reports where the person pulled a sample from the reservoir and the pan, and they did get different results. They were minor differences but they were different. I plan on putting in a by-pass filter for my oil and I think that will do a better job cleaning all of the oil which will make the high pressure oil cleaner. Obviously changing the reservoir oil will not hurt and could be done as a good measure for those that like to go above and beyond on their maintenance. I change my oil every 3k, so I overchange it to some standards, but I only put on 5k per year. I recently sent my oil in to Blackstone and they cam back telling me to run it 5k before the next sample.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
