Diesel Forum - TheDieselStop.com - View Single Post - EGR Cooler -Engine Failure - *PICTURES*
Old 11-07-2009, 04:36 PM   #73 (permalink)
djshum
Have you looked at the piston closely yourself? Use a pick and dig the object out of the piston and post a picture of JUST the object. It is hard to see it in the picture with the glare of the flash. Make sure you have plenty of pictures of object embedded in piston, then dig around/use side cutters to cut aluminum out, to get object out of piston to get a better look. It appears that the wire has an object attached to it and it is embedded in piston.
djshum is offline
