Diesel Forum - TheDieselStop.com - View Single Post - adding CAC to existing dt466 motor
Old 11-07-2009, 05:45 PM   #21 (permalink)
hemivolvo
hemivolvo's Avatar
OK i looked today and there are two 1/8 pipe plugs in manafold just above turbo i took one out and switched the sensor, took it out on hwy pushed it on more or less level and got close to 1100 but not quite, the only real hill around here is 50 mile round trip, didnt have time to go that far.my feeling still holds i was measuring in the wrong place but proved i only had 50 to 100 degree difference.
quote ''diesel tech showed you the max fuel screw (if not, post it & I'll guide you) Turn this screw out 1/4 turn and roadtest ''
the last two posts have been very helpful the tech told me to turn the screw in as toward the front to ritchen the mixture, i was thinking out made more sence please post proper direction and ill try to get it first part of the week
thank you so much for any info and ill get to it ASAP
hemivolvo is offline   Reply With Quote
