I know I'll probably get heat for this but there is NO WAY you can do HID properly without changing out the reflectors. The focal length and light distribution pattern cannot be matched with a bulb change. HID's CANNOT sit at the proper depth and position in a reflector that is designed for and incandescent bulb. You'll get light where you don't want it or need it, and too little where you do need it. Not to mention they are not DOT approved, therefore not legal.
