Replaced the CPS with a ford factory one ($27 not bad).. still no start.
the HPOP is full of oil, fuel is discharged from the schrader valve when cranking, but no ignition. after a couple battery disconnects,, etc, I keep getting the following codes:
P0472
P0340
P0603
I replaced the new CPS with the old one and no go.
btw, the new CPS was different than the old one. The 'sensor' part of the new one was a smaller diameter. not sure if this matters or not.
Checked the fuses, they all are good...
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
