Diesel Forum - TheDieselStop.com - View Single Post - 2000 F350 Questions
Old 11-07-2009, 10:53 PM   #5 (permalink)
woodnthings8
woodnthings8's Avatar
Oil leaks in the valley are not that uncommon, they can usually be fixed with o-rings and a little time. Often times the intercooler boots seep oil and that creates an oily mess however it usually does not puddle up. Turbo orings, back pressure actuator, & hpop is the common oil leak generators on the 7.3.
The turbos are a gold color from the factory so I dont think that is an issue.
The smoke at start-up is something to watch after it has been run and you start again. White smoke is unburnt fuel and the blue is oil obviously. It could be like you said and just had not been run in a while.
20k is far too much for a y2k IMO. That truck should not be any more than 12-15k, I haven't booked it out but that seems high.
You need to have the ses light looked at before buying, to me any dealer selling a vehicle with a ses light is not one to buy from.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
