has anyone removed the piston and checked for wormed out or walked ring as i seen one that worked its way somehow out of ring land and no sign of exit piont on piston untill removed and inspected,also back in 04 i saw one that had a small bolt left in intake from factory and looked somewat like that after bein smashed around,,,,,,,,,also you should check intake air temp manifold sensor,tip could have done that ,also intake air plate screw on throttle plate looks somewhat like that.........no wonder i no longer work for ford ,,,go easy on tech as he probably didnt get payed for the job!!!!
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............
