I would check the hpop pressure when you are cranking. I think you are low on the hpop pressure when you idle and could have injector o ring dumping oil or the ipr is not seating. The hpop psi needs to be at 500 or higher to start or injectors will not be told to work from computer, When you shhot either in then it fires up and now the rpm are high enough to possibly hit the needed 500 psi so it then starts,
Again you need to monitor the hpop psi when it no starts
You could have worn poppet valves in some injectors and depending on upper or lower poppet seats worn it could cause no start warm or no start cold.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60  , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps, Tony Wildman  Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
