Put the new CPS sensor back in and disconnect the batteries for a few minutes and put your key in the ignition and turn the key like you would try to start the truck then hook your batteries back up and try and start it. Disconnecting the batteries and attempting to start it drains all residual power from the capacitors inside the PCM and erases all memory. See if that works.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
