Old 11-08-2009, 11:22 AM   #22 (permalink)
hemivolvo
hemivolvo's Avatar
in response to evel486 yes i have the ambac model 100 pump, i did find some info last nite on this pump found some exploded views, no instruction on adj though. i took off the motor cover today and got a good look at pump i think the four bolt cover on top is where the ''screw'' is located comes with warning lable about changing mixture, it is not a cover but a box, the aneroid tube hooks to the rear of the box directly in front of the manual prime pump, do i remove tube and pull the box off to get to adj screw?
thank you for any advice also while i got you i want to turn up govenor approx 100 rpm as red line is listed at2600 and mostly i only get 2500, i believe this screw is the acorn nut at the back of pump at the very bottom does that acorn nut do the adj or does it come off and adj under the nut?
thanks again
hemivolvo is offline   Reply With Quote
