Originally Posted by 05Duallyon22s
If you brake torque it, does it try to spool or no? Can you hear the turbo doing anything?
Reason I ask, is i've seen cases where you can look at the side tanks of the intercooler and they look fine. Under boost though, a seam will open up, but with no boost, everything looks normal... Matter of fact you couldn't even make the seam open up by tools. You don't realize how much force a few pounds of boost is..
what is brake torque?
the turbo sounds like it spools, no boost at all, the boost gauge says 0. the truck feels like it does not have a turbo. anyway i can check the intercooler? and to take the intercooler off, i have to remove the radiator?
