Originally Posted by StrRacerX
what is brake torque?
the turbo sounds like it spools, no boost at all, the boost gauge says 0. the truck feels like it does not have a turbo. anyway i can check the intercooler? and to take the intercooler off, i have to remove the radiator?
Obviously be careful.
But have someone in the truck hold the brake down as hard as possible, get on the gas let it try to spool up like you are going to launch while you are listening for leaks.
Alternate method : How to: make a slightly more baller boost leak detector - evolutionm.net
Without taking the IC off, you can take the hoses off (the motor side not the ic side) Plug up one side.
On the other side
Rig up something (like pvc cap and some connectors) so you can connect an air hose fitting up to and it take it (start of low 1 psi) up to 40 PSI, This will test all your hoses and IC. IF it holds you are good, if not, you know you got a leak..
Sort of like a radiator pressure tester..
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
http://www.youtube.com/watch?v=M2zEFb6bFLc - Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
