[/quote]Since I'll be boosting the power with an aftermarket product...should I also get some sort of EGT monitoring?[/quote]
You need lots of monitoring to properly own a diesel and be an educated owner LOL.
Minimum is:
Boost
EGT (ignore EGT = Ignore the Engine)
Oil Temp vs Engine Coolant Temp
Tranny Temp
* FUEL Pressure (Requires a gauge or a sensor with sending unit to the cab).
ALL of these plus many more can be done economically with an EDGE Insight MONITOR for less than the cost of most gauge setups.
