Diesel Forum - TheDieselStop.com - View Single Post - troubleshooting 6.0 turbo
Old 11-08-2009, 08:15 PM   #3 (permalink)
pbjelsberry
Originally Posted by djshum View Post
Inferred ebp, which your 6.0 has, is very touchy with exhaust leaks, intake leaks, and aftermarket products. Check your MAF sensor also, and clean it, as the oil from the filter gets on the wires of the sensor and lets dirt stick, causing false readings. Would recommend switching back to stock filter. Could also be a turbo....find someone capable of doing a proper diag. as there are many issues that will give symptoms you describe.
Will look into those things a.s.a.p. I just keep trying to apply logic to all this, what would cause it to go into deep six after ideling for a little while that reseting would cure. I don't want to just throw parts at it, can
t afford to
pbjelsberry is offline   Reply With Quote
