Diesel Forum - TheDieselStop.com - View Single Post - 4wd Conversion
Thread: 4wd Conversion
Old 11-08-2009, 09:48 PM   #39 (permalink)
44boggers
yeah the ouputs have to be changed and when you do you do away with the tailshaft housing off the 2wd tranny
as far as the parts off the frame the best bet is find a boneyard with a truck you can salvage from thats the cheapes as from ford would cost quite a bit
the floor shift case is easy to make the dash lights work you need to but a tranny harness from ford relativly cheap and remove dead plate from under carpet and carefully cut carpet and install shifter on case
01 F350 Lariat CC DRW 2x4 Auto (now with 4x4 conversion)
TS chip 50/75/100/120 with PMT1
AFE stage one cross with some k&n fipk parts
Autometer guages (Pyro, Trans Temp, Boost)
Wicked Wheel and TAG 1&2
4" MBRP exhaust (stainless)
Billet grille & 02 headlights
Line-X
PTC triple disc converter, tugger kit, sonnax valves,cooler bypass delete, upgraded internals, suncoast coast clutch drum
future mods:king ranch interior,painted heated signal mirrors
44boggers is offline   Reply With Quote
