Diesel Forum - TheDieselStop.com - View Single Post - Help Please Speedometer problem
Old 11-08-2009, 11:45 PM   #2 (permalink)
woodnthings8
woodnthings8's Avatar
Your speedo gets its signal thru the ABS module, it gets signals from the rear vss sensor. If you have an ABS light you probably have other issues.
You o/d light can be burnt out, does it shift into o/d and can you cancel it with the button?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
