Here is what the manual says about the speed signal;
The instrument cluster is hardwired to the four wheel anti-lock brake system (4WABS) module. The instrument cluster micro-processor monitors the VSS data from the 4WABS module and commands the speedometer with a corresponding movement of the pointer. The vehicle speed signal is generated by the rear anti-lock brake sensor and sent to the 4WABS module. The 4WABS module sends the vehicle speed signal via circuit 679 (GY/BK) to all systems that require a vehicle speed signal input.
Ken
Powerstroke Acronyms
TSB Information
