you could run a zero rate or re-drill the perches to move the axle foward...
alcan spring can make you custom leafs that can will push the axle foward
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
