I say piece of turbo blade. How come the piston looks real sloppy in the bore? It would be nice to see if all the pieces of piston rings are there as well and not broken off. I had that happen once, took out some valves and that cylinder.
Take an oil sample and coolant sample if there is any left, this may help if it goes to court. We had an engine failure on a 3508 Cat and found foreign material in the base. We had the foreign material tested and the oil tested and determined through this analysis that the engine was sabotaged by someone as the tests proved that the material was not part of the oil nor the engine. The insurance company paid up after that determined. It wasn't fun, it was battle right to the end. STICK TO YOUR GUNS AND DON'T BACK DOWN.
There was something foreign in there that is for sure.
K3 F350 6.0l 4x4, Crew cab, Lariat, shortbox, T.red, 285 BFG All Terrains, Sirius Radio, SS Grille, Silverstar fog and headlights, Boost and Fuel pressure gauges-Lunar Series Autometer. KYB MonoMax shocks 5w40 Delvac 1 14.7 mpg town.
