Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 11-09-2009, 07:41 AM   #8 (permalink)
ridintall
ridintall's Avatar
Originally Posted by MikeL46 View Post
It looks like your heater hoses are more accessible than mine. On my van the hoses never come forward of the back of the alternator. I can barely see them, and can almost touch them. And it is worse from the backside.
But, I have purchased the Dieselsite kit and am pondering what to do.
Mike
I wouldn't say the heater hoses on my van were accessible. They were definitely under the cowl and to the side of the alternator. Basically there's stuff all around them and barely enough room to work. It was a PIA but I'm glad i did it. I've had to top off my coolant several times since the install. I can't find a leak anywhere. I'll start to worry once I've topped off more than a gallon of coolant..for now, I'm just keeping an eye on it.
Too bad your not closer, I'd be glad to give you a hand with the install.
BTW, I put together an emergency repair kit. It's a length of 3/4" heater hose, barbed fittings and hose clamps....just in case. I had to buy a whole pack of the 3/4 barbed fittings and only needed two so if you decide to do the same send me a PM.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline   Reply With Quote
