Diesel Forum - TheDieselStop.com - View Single Post - 99 PSD with miss(es) and intermitten
Old 11-09-2009, 09:41 AM   #4 (permalink)
4x4Nut
Originally Posted by hstechteacher View Post
hello,
I have a very similar problem with the same truck/year. however, mine is even more annoying in that it goes away totally and comes back. If I shut the truck down and restart, sometimes the miss goes away. I have not done anything as far as trouble shooting. what is the deal the with injector clips? (I saw that on another post too). I am thinking electrical??? let me know how you make out I, I might try the same things
This one won't restart fine if it's missing. It doesn't come and go that bad. The clips are for the under valve cover wire harness. Where the harness plugs into the valve cover gasket, the catch to lock the connector in place can weaken and come loose. When this does it will break circuit to the injector(s). There are clips to install in order to keep the connections locked in place.
I'm going to work on the truck more this week to try to figure it out. Any suggestions are still welcome though.
4x4Nut is offline   Reply With Quote
