Diesel Forum - TheDieselStop.com - View Single Post - Changed Fuel Filters.
Old 11-09-2009, 11:11 AM   #8 (permalink)
pontiacu787
Filter Change
[quote=senix;1803879]good deal. when I change mine the fuel cutoff is very sensitive so I have to hold it down while cranking to get it to prime.quote]
I just had a problem with mine. After I changed the filters and represurized the system per the manual, turning the key on six times for 30 seconds each time but the engine wouldn't run. It would start and die after a few seconds. After doing this for about an hour I gave up and called AAA. The guy showed up to take it to the dealer and said let me try. He cycled the key quickly a few times and it started and ran fine. How do you hold down the fuel shut off to get the engine to prime?
pontiacu787 is offline   Reply With Quote
