Diesel Forum - TheDieselStop.com - View Single Post - Changed Fuel Filters.
Old 11-09-2009, 11:52 AM   #9 (permalink)
senix
senix's Avatar
[quote=pontiacu787;1806529]
Originally Posted by senix View Post
good deal. when I change mine the fuel cutoff is very sensitive so I have to hold it down while cranking to get it to prime.quote]
I just had a problem with mine. After I changed the filters and represurized the system per the manual, turning the key on six times for 30 seconds each time but the engine wouldn't run. It would start and die after a few seconds. After doing this for about an hour I gave up and called AAA. The guy showed up to take it to the dealer and said let me try. He cycled the key quickly a few times and it started and ran fine. How do you hold down the fuel shut off to get the engine to prime?
Open front passenger door, right on the side of the dash is door to open and then the switch is right there.
This cutoff switch is designed for crashes and as you can see...it is sensitive
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 14K.
senix is online now   Reply With Quote
