Diesel Forum - TheDieselStop.com - View Single Post - wanted: better mileage
Old 11-09-2009, 11:58 AM   #13 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
Originally Posted by sdwarf36 View Post
I took a ride down the hiway yesterday-while looking over at the AIC tach, 65mph works out to 2500 rpm. I'm betting that means the 4.10 gear.
I'll bet that means 4.56 or 4.88 gears, probably 4.56.
Assuming you don't have a locker or a limited slip rear end, you can find out. Put blocks under both front tires, in front of and behind the tires, put the trans in neutral, Parking brake off, jack up one rear wheel, mark the bottom of the raised tire,
crawl under and mark the driveshaft. Rotate the driveshaft and count the number of rotations of the driveshaft that are needed to rotate the tire 2 revolutions. That number is your gear ratio.
If you have locker or limited slip, you have to jack up both rear wheels and count for one turn of the rear tires.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
