Diesel Forum - TheDieselStop.com - View Single Post - upgrade intercooler ? ? ?
Old 11-09-2009, 02:41 PM   #9 (permalink)
ronchyhiker
Thanks for the reply.So what is the big deal.The 7.3 is 30in.wide X18in.high=540sq.in. the 6.0 is 25.75in. wide X 21in. high=540.75. The only difference is thickness of .25in.
Is there something I am missing?
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline   Reply With Quote
