Diesel Forum - TheDieselStop.com - View Single Post - Dieselsite Coolant filter installed - 6.0 Van
Old 11-09-2009, 07:53 PM   #9 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
Looked more closely at your pictures, you put the T in the lower heater hose. I might be able to do that. It is really hard to say 'might' and then start cutting the hose. I could never get to the upper hose without removing some AC lines and probably the alternator.
When the rain stops, I'm going to bite the bullet and start cutting.
Is it possible the coolant you have to add is to replace some that came out during the install?
Thanks for doing it and giving me the courage to try.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
