It will work without one leg of the pot grounded, for the same reason it will work with just a fixed resistor, there is a pull down resistor in the PCM which completes the voltage divider. It won't hurt anything. I would expect the PCM inputs to have protection from shorts to ground or power, but I'd be careful to keep things properly insulated so they don't short and do funky things while you're driving.
