Diesel Forum - TheDieselStop.com - View Single Post - Remote starter problems
Old 11-09-2009, 08:37 PM   #7 (permalink)
hhall1114
Yeah when I use the remote start everything works fine except the edge. The heat and everything else, even after i put the key in and go everything is fine. I have the ultra start with feedback installed. I talked to a guy from huckstorf diesel and he said the edge is wired into the fuse panel, so I dont know if theres a relay or fuse for the ignition that would tell the edge to power up, or if there is a wire that runs to the ignition from the fuse panel. But if that was the case the edge should power up with the remote start.
hhall1114 is offline   Reply With Quote
