Diesel Forum - TheDieselStop.com - View Single Post - adding CAC to existing dt466 motor
Old 11-09-2009, 09:46 PM   #24 (permalink)
Evel486
hemivolvo- I've been gone for a few days. It's been quite a few years since I've worked on a Model 100 so here goes.
The max fuel screw moves the camplate (see your illustration) You want to move the camplate forward to increase max fuel. If I recall correctly, turning the screw counter-clockwise will increase. Try about 1/4 turn to begin.
Your rated full load speed is 2600 rpm. To achieve this your high idle should be 3100 rpm. High idle is the rpm you get at wide open throttle in neutral. The screw for adjusting this is the one with the cap on it. The screw next to it without the cap is for low idle (adjust to 650 rpm)
If you have white or grey smoke at cold start up, you may have to adjust the timing. If so, post it and I'll give you instructions.
Adjust your fuel and road test. You can judge by your gauges whether to give it more or back it off. (You can also use your right foot to back it off)
Evel486 is offline   Reply With Quote
